Audi A4 2013 model, Knocking sound from rear right end of car
Hi @Christopher Royare you sure the shop used the right type of break pads for the car ? I suspect there is a little bit of play and they are slightly loose, making them slide forward when braking.
You posted this in the RS4 section. Perhaps the workshop installed the regular A4 brake pads ? (I would assume the RS4 has provision for bigger type of brake pads).
