Luke K P Posted April 26, 2023 Share Posted April 26, 2023 Hi, I just changed out my stock rims for some offroad ones, with a different offset and now the pajero wheel cover wont close due to the diff offset. Considering just cutting this guy (the spare mount) and re welding it about 5cm shorter. Is there a better option i should be considering...???? or shoud i just get choppy and weldy? Link to comment Share on other sites More sharing options...
Stumpy Posted April 26, 2023 Share Posted April 26, 2023 Quite a few people just make a spacer to pack it out, this one’s a bit extreme but you get the idea. I think the best option is to delete the trim altogether, I think this looks the best and is the most functional there are also spacers available to lift the tyre up when fitting larger tires. you can just turn the mount upside down to achieve the same thing but a bit more work cutting the studs off and swapping them 1 1 Link to comment Share on other sites More sharing options...
Luke K P Posted April 27, 2023 Author Share Posted April 27, 2023 12 hours ago, Stumpy Paj said: Quite a few people just make a spacer to pack it out, this one’s a bit extreme but you get the idea. i actually have the opposite problem to this,... my wheel is sticking waaay out because of the bracket. and the door wont close due to it sticking out. But yes i think deleteing the entire back panel might be a nicer look. 1 Link to comment Share on other sites More sharing options...
Frederic Posted April 27, 2023 Share Posted April 27, 2023 11 minutes ago, PETELCZYC PAJERO - luke said: i actually have the opposite problem to this,... my wheel is sticking waaay out because of the bracket. and the door wont close due to it sticking out. But yes i think deleteing the entire back panel might be a nicer look. Make sure to keep your license plate lighting working. Otherwise the RTA will not pass it. 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Stumpy Posted April 27, 2023 Share Posted April 27, 2023 1 hour ago, PETELCZYC PAJERO - luke said: i actually have the opposite problem to this,... my wheel is sticking waaay out because of the bracket. and the door wont close due to it sticking out. But yes i think deleteing the entire back panel might be a nicer look. Yeh I agree, I want to delete the rubbish looking plastic as well, makes it easier to get to the wheel and you can mount fuel containers as well. There are people who make the delete panels and the mount for the licence plate, just haven’t found where in Dubai yet. If you do can you let me know? 1 Link to comment Share on other sites More sharing options...
Luke K P Posted April 27, 2023 Author Share Posted April 27, 2023 22 minutes ago, Stumpy Paj said: Yeh I agree, I want to delete the rubbish looking plastic as well, makes it easier to get to the wheel and you can mount fuel containers as well. There are people who make the delete panels and the mount for the licence plate, just haven’t found where in Dubai yet. If you do can you let me know? Sure if i find somewhere to do it i will let you know! 1 Link to comment Share on other sites More sharing options...
Luke K P Posted June 26, 2023 Author Share Posted June 26, 2023 On 4/27/2023 at 10:09 AM, Stumpy Paj said: Yeh I agree, I want to delete the rubbish looking plastic as well, makes it easier to get to the wheel and you can mount fuel containers as well. There are people who make the delete panels and the mount for the licence plate, just haven’t found where in Dubai yet. If you do can you let me know? After strapping the spare in the back for a month I got an angle grinder and just chopped up the spare mount so the new rim fits. Couldn't find a plastic delete place that didn't look terrible as the end result over here in Abu Dhabi. Can't tell from the outside how I butchered that poor mount 😅😅 2 1 Link to comment Share on other sites More sharing options...
