Newbie Just got a Army Basecamp Model Exterra.
Hey everyone, I’m a newbie and would love some insight and suggestions on what basic mods I should do to my car for sand driving. I’d really appreciate any valuable input from the community and fellow off-roaders.
My car is old 2010 ex military BaseCamp Model, it has 4x4 but i dont see any VDC switch
Hi @Heavenkepper
You are lucky: A Nissan Xterra does not need much as it's very capable in stock condition.  There are however a few points to consider:
1. Technical condition. Get it checked completely and serviced before taking it on the sand. Breaking down in the desert is not fun.
2. The stock tow points/recovery points (front and back) can be a bit weak. Many Xterra owners upgrade these. If yours still look OK and are not entirely rusted they will do fine, but if you plan to take it regularly into the desert, it is highly recommended.
3. A custom made bash-plate is a good addition if you start off-roading regularly. It will protect your radiator.
4. A flag holder will be necessary if you drive with the club. Suction cup is a good alternative.
The reason you don't have a VDC switch is because the basecamp model did not come with traction control. At least that's one less thing to worry about :)
You will however need to turn off the ABS. This can be done by pulling the ABS fuse inside the electrical fuse box of the engine bay. If you don't like pulling this ABS fuse every time, you can get a killswitch installed, which is a small switch located underneath the dashboard that allows you to turn off the ABS instantly without having to pull any fuses.
