musit Posted October 19, 2011 Share Posted October 19, 2011 Where is the Fuel Pump Relay located in 1992 Honda Accord? Link to comment Share on other sites More sharing options...
zubs Posted October 21, 2011 Share Posted October 21, 2011 located behind left side of dash. Link to comment Share on other sites More sharing options...
dasautoservices Posted July 27, 2012 Share Posted July 27, 2012 Fuel pump is located at the rear fuel tank, you can open the rear boot there is a small cover, when you remove cover you can see 6, 10mm nuts, remove and replace Link to comment Share on other sites More sharing options...
musit Posted March 26, 2013 Author Share Posted March 26, 2013 What is the self life of fuel pump? Link to comment Share on other sites More sharing options...
transporter2222 Posted April 23, 2013 Share Posted April 23, 2013 The fuel pump is located in the boot/ trunk under the cover. And its life depends on kms like around 1.5 lac kms are enough to change the fuel pump. Link to comment Share on other sites More sharing options...
talal Posted May 12, 2013 Share Posted May 12, 2013 1.5 lac means 150k = 150,000 kms. Link to comment Share on other sites More sharing options...
musit Posted May 30, 2013 Author Share Posted May 30, 2013 Thank you transporter and talal Link to comment Share on other sites More sharing options...
