AudiDxb Posted May 3, 2012 Share Posted May 3, 2012 AUDI FAULT CODES [VAG and SAE (OBD-II)] Please find list of all possible Fault Codes in Audi. In case we have missed some, please add it in reply for others to follow. Explanation and solution to most of the fault codes can be found at below link: http://wiki.ross-tech.com/wiki/index.ph ... ault_Codes Diagnostic Trouble Code (DTC) Definitions The following Diagnostic Trouble Code (DTC) definitions lists provide both VAG and SAE (OBD-II) trouble codes. For codes not listed in this table, consult the vehicle’s service workshop. 00277 ABS Inlet or Outlet Valve - Left Front (N137) 00278 ABS Main Valve (N105) 00279 Differential Lock Valve 1 (N125) 00280 Differential Lock Valve 2 (N126) 00281 Vehicle Speed Sensor -No Signal (G68) 00282 Throttle Position Actuator -V60 00283 P1711 ABS Wheel Speed Signal #1 (Left Front) - Range/Performance -G47 00284 ABS Inlet or Outlet Valve - Right Front - N138 00285 P1716 ABS Wheel Speed Signal #2 (Right Front) -Range/Performance - G45 00286 ABS Inlet or Outlet Valve - Left Front -N139 00287 P1721 ABS Wheel Speed Signal #3(Right Rear) -Range/Performance (G44) 00289 ABS Inlet or Outlet Valve - Right Rear (N140) 00290 P1726 ABS Wheel Speed Signal #4 (Left Rear) - Range/Performance. (G46) 00291 Pressure / Fluid Level Warning Switch (F116 / F117) 00292 Hydraulic Energy Supply Pressure Level 00293 P0705 Multi-Function Transmission Range Switch - Malfunction (PRNDL Input) (F125) 00294 Transmission Pressure Switch L (F174) 00295 Transmission Pressure Switch 2 (F175) 00296 P1704 Kick-down Switch - Short to ground (F8) 00297 P0715 Input/Turbine Speed Sensor Circuit - Malfunction 00297 P0721 Vehicle Speed Sensor Circuit - Range/Performance -Signal Noisy (G38) 00297 P0722 Vehicle Speed Sensor Circuit - No Signal 00297 Transmission Vehicle Speed Sensor (G38) 00298 Rear Differential Lock Switch -E121 00299 Transmission Shift-Range Program Switch -Short Circuit -E122 00300 P0712 Transmission Fluid Temperature Sensor Circuit Low Input (G93) 00300 P0713 Transmission Fluid Temperature Sensor Circuit High Input (G93) 00301 ABS Return-flow Pump (V39) 00302 ABS Solenoid Valve Relay (J106) 00303 Board Computer Function Selector Switch (E91) 00305 Fuel Consumption Indicator Signal 00306 Secondary Air Injection - Cylinder Bank 1 00307 Secondary Air Injection - Cylinder Bank 2 00309 Cleaning Solution Metering Pump (V135) 00310 Catalytic Convertor Temperature Sensors (G20) 00312 Catalytic Convertor Control Temperature Sensors (G132) 00313 Three Way Catalytic Converter -Signal Malfunction 00314 EGR Two Way Valve (N161) 00447 ABS-ASR Motor -Electrical Connection 2 00501 Central Flap Motor Position Sensor -G92 00512 P0341 Cam Sensor -Signal Error 00512 Camshaft Position Sensor - Not on Reference Mark 00513 P0506 Engine Speed Sensor -G28 -Idle RPM Too Low 00513 P0507 Engine Speed Sensor -G28 -Idle RPM Too High 00513 Engine Speed Sensor -G28 -Signal Malfunction 00514 P0336 Crankshaft Position Sensor -Erratic Signal - G4 00514 Crankshaft Position Sensor -G4 00515 P0340 Camshaft Position Sensor (Hall Effect Sensor) -No Signal (G40) : Check CMP, if OK, replace distributor. 00515 Camshaft Position Sensor (Hall Effect Sensor) -Short to B+ (G40) : Check CMP, if OK, replace distributor. 00516 Throttle Position Sensor -Closed Switch -F60 00517 Throttle Position Sensor -Wide-open Switch -F81 00518 P0121 Throttle Position Sensor -Signal Out of Range (G69) Also check for loose ECM power relay. 00519 P0106 MAP Sensor -Out of Range -G71 00519 P0107 MAP Sensor -Voltage Low -G71 00519 P0108 MAP Sensor -Voltage High -G71 00520 Volume Mass Air Flow Sensor -G19ig70 00521 Co Fuel Trim Potentiometer -G74 00522 Engine Coolant Temperature Sensor -G62 00523 P0112 IAT Sensor - Temp High -Circuit Low - G42 00523 P0113 IAT Sensor - Temp Low - Circuit High - G42 00524 Knock Sensor 1 -G61 00525 P0131 O2 Sensor -Voltage Low -G39 00526 Brake Light Switch -Incorrect signal (F) 00527 Intake Air Temperature Sensor -G72 00528 Barometric Pressure Sensor -F96 00529 P0725 Engine Speed Input Circuit (RPM Sensor) - Malfunction. Also check for loose ECM power relay. 00529 P0727 Engine Speed Input Circuit (RPM Sensor) –No Signal 00530 Throttle Position Sensor -G88 00531 Mass Air Flow Sensor Reference Voltage 00532 P1746 Transmission Control Module Relay - Supply Voltage (B+) Malfunction Low Battery or Bad Ground 00532 P1750 Supply Voltage (B+) 00533 Idle Air Control Regulation 00534 Oil Temperature Sensor -G8 00535 First Knock Sensor 00536 Second Knock Sensor 00537 Oxygen Sensor Control 00538 Reference Voltage 00539 Fuel Temperature Sensor -G81 00540 Knock Sensor 2 -G66 00541 Slide Travel Sensor -G99 00542 Needle Lift Sensor -G80 00543 P0726 Engine Speed Input Circuit - RPM Upper Limit Exceeded 00544 Maximum Charge Air Pressure Exceeded 00545 P1780 Engine Intervention Unreadable. Also check for loose ECM power relay. 00545 P1781 Engine Intervention Stuck Off. Also check for loose ECM power relay. 00545 P1782 Engine Intervention Stuck On. Also check for loose ECM power relay. 00546 Data Communication Line Faulty 00547 ABS Pressure Control Switch -F137 00548 P0560 System Voltage Malfunction 00549 Fuel Consumption Signal 00549 P1771 Load Signal Stuck Off (RPM Signal missing) 00549 P1772 Load Signal Stuck On (RPM Signal missing) 00550 Injection Start Control 00551 Catalytic Convertor Excess Temperature 00552 Volume Air Flow Sensor (Position Sensor) -G19 00553 Mass Air Flow Sensor -G70 00554 Oxygen Sensor 2 - Control 00555 Heating Circuit - Oxygen Sensor 2 -G108 00558 Mixture Control Adjustment Limit - Lean Position 00559 Mixture Control Adjustment Limit - Rich Position 00560 EGR Temperature Sensor Switch Short or Implausible Value 00561 Mixture Adjustment Control 00575 Manifold Absolute Pressure Sensor 00577 Knock Sensor Control -Cylinder 1 00578 Knock Sensor Control -Cylinder 2 00579 Knock Sensor Control -Cylinder 3 00580 Knock Sensor Control -Cylinder 4 00581 Knock Sensor Control -Cylinder 5 00582 Knock Sensor Control -Cylinder 6 00583 Knock Sensor Control -Cylinder 7 00584 Knock Sensor Control -Cylinder 8 00585 EGR Temperature Sensor -G98 00586 EGR System Control 00587 Mixture Control Adjustment Limit - Bad ECU ground, Air leak, Leaking Injector. 00588 Air-bag Ignition Circuit - Driver Side -N95 00589 Air-bag Ignition Circuit 1 - Passenger Side -N131 00590 Air-bag Ignition Circuit 1 - Passenger Side -N132 00591 Seat Belt Tensioner Switch - E24 00592 Seat Smelt Tensioner Switch - E25 00593 Seat Detect Switch - Passenger Side -F151 00594 Air-bag Ignition Circuit 00595 Crash Data Already Stored 00596 Injector or Trans. Solenoid Wires - Short 00597 P1728 Varying ABS Wheel Speed Signals -Range/Performance 00598 Hydraulic/Mechanical Malfunction 00599 Possibility-pressure Brake Light Switch 00600 Temperature Regulator Flap Motor Position Sensor -G92 00602 Foot-wall/defroster. Flap Motor Position Sensor -G114 00603 Foot-wall/defroster Flap Motor -V85 00604 Back Pressure Flap Motor Position Sensor -G113 00605 Fresh Air Recirculation Flap Two-way Valve -N63 00606 Engine Coolant Two-way Valve -N147 00607 Outside Air Temperature Display -G106 00608 Load Sensor -G119 00609 Ignition Output 1 00610 Ignition Output 2 00611 Ignition Output 3 00612 Ignition Output 4 00613 Ignition Output 5 00614 Ignition Output 6 00615 Ignition Output 7 00616 Ignition Output 8 00617 Air-bag Deceleration Sensor -Left -G104 00618 Air-bag Deceleration Sensor -Right -G105 00619 Sensor Supply Line - Left 00620 Sensor Supply Line - Right 00621 Pressure Reduction Valve -N155 00622 Draining Water from Fuel Filter 00623 ABS/Transmission Electrical Connection 00624 A/C Compressor Engagement 00625 Vehicle Speed Signal 00626 Glow Plug Indicator Light -29 00627 Water Level Sensor -G120 00628 Actuating Variable Control 00629 Vacuum Vent Valve - Brake -F47 00630 A/C Switched on 00633 Wiring to Ignition/sensor for Delay 00634 Series Resistance -N159 00635 Oxygen Sensor Heating Circuit -Ahead of Catalytic Convertor 00636 Acceleration Sensor -Right Front - G121 00637 Acceleration Sensor -Left Front - G122 00638 P1766 Throttle Angle Signal - Stuck Off. Also check for loose ECM power relay. 00638 P1767 Throttle Angle Signal - Stuck On. Also check for loose ECM power relay. 00638 Engine/Transmission Electrical Connection 2. Also check for loose ECM power relay. 00639 Deceleration Sensor -G123 00640 Oxygen Sensor Heating Relay -J278 00641 ATF-Temperature too High 00642 EDL Switch-over Valve - Right Front - N166 00643 EDL Outlet Valve - Right Front -N167 00644 EDL Switch-over Valve - Left Front -N168 00645 EDL Outlet Valve - Left Front - N169 00646 ABS-ASR Motor -Electrical Connection 1 00648 Oxygen Sensor Heating Circuit -Behind Catalytic Convertor 00649 ABS Inlet/outlet Valve - Rear -N160 00650 Clutch Vacuum Vent Valve Switch -F36 00651 Ignition Wiring 00652 P0730 Transmission Shift-Range Controller -Incorrect Gear Ratio 00652 P0731 Transmission Shift-Range Controller -Gear #1 -Incorrect Ratio 00652 P0732 Transmission Shift-Range Controller -Gear #2 -Incorrect Ratio 00652 P0733 Transmission Shift-Range Controller -Gear #3 -Incorrect Ratio 00652 P0734 Transmission Shift-Range Controller -Gear #4 -Incorrect Ratio 00653 Automatic Transmission Selector Lever 00654 Seat Belt Tensioner Igniter 1 -N153 00655 Seat Belt Tensioner Igniter 1 -N154 00656 Air-bag Seat Detect Sensor -G128 00657 Center Vent Adjusting Motor -V102 00658 Operating Module 00659 Self Test 00660 Kick-down Switch / Throttle Position Sensor 00661 Temperature Indicator 00662 Tachometer -G5 00663 Speedometer -G21 00664 Fuel Gauge 00665 Seat Belt Warning Light -K19 00666 Signal 00667 Ambient-temperature Signal 00668 Battery Power Voltage Supply (Terminal 30) 00669 Secondary Mil -K97, 00670 Throttle Position Sensor -G127 00671 Cruise Control Switch -E45 - Undefined Switch Position 00672 ABS Hydraulic Pump with Series Resistance 00673 Brake Pedal Pressed 00674 Brake Released 00675 IV-Left Front: OV OV-Left Front; OV - Left Front Wheel Locked 00676 IV-Left Front: B+ OV-Left Front: OV - Left Front Wheel Locked 00677 IV-Left Front: B+ OV-Left Front: B+ -Left Front Wheel Free 00678 IV-Left Front: B+ OV-Left Front: OV - Left Front Wheel Free 00679 Oxygen Sensor Heating Circuit in Front of Catalytic Convertor 00680 IV-Right Front: OV OV-Right Front: OV - Right Front Wheel Locked 00681 IV-Right Front: B+ OV-Right Front: OV - Right Front Wheel Locked 00682 IV-Right Front: B+ OV-Right Front: B+ -Right Front Wheel Free 00683 IV-Right Front: B+ OV-Right Front: OV - Right Front Wheel Free 00684 Oxygen Sensor Heating Circuit. Behind Catalytic Convertor 00685 IV-Left Rear: OV OV-Left Rear: OV - Left Rear Wheel Locked 00686 IV-Left Rear: B+ OV-Left Rear: OV - Left Rear Wheel Locked 00687 IV-Left Rear: B+ OV-Left Rear: B+ -Left Rear Wheel Free 00688 IV-Left Rear: B+ OV-Left Rear: OV - Left Rear Wheel Free 00689 Outside Air in Intake Air System 00690 IV-Right Rear: OV OV-Right Rear: OV - Right Rear Wheel Locked 00691 IV-Right Rear: B+ OV-Right Rear: OV -Right Rear Wheel Locked 00692 IV-Right Rear: B+ OV-Right Rear: B+ - Right Rear Wheel Free 00693 IV-Right Rear: B+ OV-Right Rear: OV -Right Rear Wheel Free 00694 Switch and Instrument Lighting 00695 Hydraulic Pump (B+) -Left Front/right Front Wheel Looked 00696 ABS Pressure Reducing Valve. -N170 00697 ABS Pressure Reducing Valve. -N171 00698 Control Module Increased Current Consumption 00699 Oxygen Sensor I - Behind Catalytic Convertor -G130 00700 Oxygen Sensor 2 - Behind Catalytic Convertor -G131 00701 ECT Overheat Test 00702 Flexible Fuel Sensor -G133 00703 CTP Recognition TPS/CTP Switch 00705 Coolant Fan Switched on 00709 Sunlight Photo Sensor 2-g134 00710 Defroster Flap Motor -V107 00711 Left Foot Well Flap Motor -V108 00712 Right Foot Well Flap Motor -V109 00713 Left Center Vent Motor -110 00714 Right Center Vent Motor -V111 00715 Rear Foot Well Vent Motor -V112 00716 Recirculation Flap Motor -V113 00717 EVAP Flap Motor -V114 00718 Upper Left Vent Switch -F179 00719 Upper Right Vent Switch -F180 00720 Lower Left Vent Switch -F181 00721 Left Right Vent Switch -F182 00722 Left Center Vent Switch -F183 00723 Right Center Vent Switch -F184 00724 Left Center Foot Well Vent Switch -F185 00725 Right Rear Foot Well Vent Switch -F186 00726 Center Rear Foot Well Vent Switch -F187 00727 Defroster Flap Motor - Position Sensor -G135 00728 Left Center Vent Motor -Position Sensor -G136 00729 Right Center Vent Motor -Position Sensor -G137 00730 Center Vent Motor - Position Sensor -G138 00731 Left Foot Well Flap Motor -Position Sensor -G139 00732 Right Foot Well Flap Motor - Position Sensor -G140 00733 Rear Foot Well Left Vent Motor -Position Sensor -G141 00734 Center Vent Position Sensor -G142 00735 Recirculation Flap Position Sensor -G143. * If this code is found on late model VR6 (AAA) refer to code #01247. 00736 EVAP Flap Motor. Position Sensor -G144 00737 Left Heat Regulating Valve -N175 00738 Rear Heat Regulating Valve -N176 00739 Coolant Pump -V50 00740 Cylinder 1 CKP Sensor -G145 00741 Brake Pedal Position Status Monitoring 00742 Battery Ventilation System 00743 Battery Ventilation Sensor -G146 00744 Battery Temperature Regulation 00745 Insulation Status Monitoring 00746 Battery Cell Failure 00747 Front Battery Temperature Sensor -G52 00748 Rear Battery Temperature Sensor -G53 00749 Ventilation Flap 00750 Fault Lamp Circuit 00751 Battery Capacity Indicator 00752 Fan and Battery Heating 00753 Electrical Connector - Wheel Speed Sensor 00754 ECT Warning Light 00755 Engine Oil Pressure Warning Light -K3 00756 Left Vent Temperature Sensor -G150 00757 Left Vent Temperature Censor -G151 00758 Secondary Air Injection System (Air) 00759 Left Vent Temperature Regulator -G155 00760 Right Vent Temperature Regulator (Actuator) -G156 00761 Diagnostic Trouble Code Stored in Control Unit 00762 Fuel Injector(s) -N181 00763 Driver Side Gas Pressure Sensor -G147 00764 Passenger Side Gas Pressure Sensor -G148 00765 Slide Control Travel (Piston Displacement) Sensor -G149 00766 Front Vent Temperature Sensor -G12 00767 Rear Evaporator Temperature Sensor R-g153 00768 Rear Heater Core Temperature Sensor -G154 00769 Engine Coolant Temperature Sensor -G82 00770 Engine Coolant Temperature Sensor -G83 00771 Fuel Level Sensor -G 00772 Oil Pressure Switch -F22 00773 Oil Pressure Sensor -G10 00774 Level Control System Sensor - Left Rear - G76 00775 Level Control System Sensor - Right Rear -G77 00776 Level Control System Sensor - Left Front - G78 00777 Throttle Position Sensor -G79 00778 Steering Angle Sensor -G85 00779 Outside Air Temperature Sensor -G17 00780 Vertical Motion Sensor -G90 00781 Positioning Motor - Left Front -V76 00782 Positioning Motor - Right Front - V77 00783 Positioning Motor - Left Front - V78 00784 Positioning Motor - Right Rear -V79 00785 Temperature Sensor -Instrument Panel -G56 00786 Temperature Sensor -in Headliner -G86 00787 Fresh Air Intake Duct Temperature Sensor -G89 00788 Foot Well/defrost Flap Two-wag Valve -N118 00789 Backup Switch -F41 00790 Recirculating/fresh Air Flap 00791 Air Conditioner Evaporator Temperature Switch -G33 00792 Air Conditioner Pressure Switch -F129 00793 Brake Pedal Position Sensor -G100 00794 Hydraulic Pump Sensor -G101 00795 Rear Axle Vertical Acceleration Sensor -G102 00796 Fan for Integer Temperature Sensor -V42 00797 Sunlight Photo Sensor -G107 00798 Segment Test 00799 Engine Coolant Temperature Sensor -G110 00800 Ambient Temperature Sensor Fresh Air Blower -G109 00801 A/C Refrigerant High Pressure Switch -F11b 00802 A/C Refrigerant Low Pressure Switch -F73 00803 Coil Spring Travel Sensor -Right Front - G118 00804 Coil Spring Trawl Sensor -Left Front -G115 00805 Suspension Strut Valve -Left Front - N148 00806 Suspension Strut Valve -Right Front - N149 00807 Suspension Strut Valve -Left Front - N150 00808 Suspension Shut Valve - Right Rear -N151 00811 System Not Ready for Activation 00824 Traction Control Indicator Light -K86 01016 Gas-filled Suspension Bleeder Valve -N106 01017 Gas-filled Suspension System Compressor -V65 01018 Coolant Fan -V7 01019 Relay 01020 Water Pump -V36 01021 Differential Lock Indicator Light -K81 01022 Interior Light -Combination Figure Activated 01023 Warning Buzzer -H3 01025 Malfunction Indicator Lamp Faulty 01027 Rear Warm Air Fan -V47 01028 Fan Relay -J323 01028 Rear Evaporator Fan -V20 01029 A/C Relay -J32 01039 ECT Sensor -G2 01040 ABS/Transmission Electrical Connection 2 01041 Traction Control System -Function Unreadable 01044 P1749 Transmission Control Module -Incorrectly Coded 01045 Tiptronic Switch -F189 01046 Broke Pod Wear Indicator Light -L32 01047 Brake and Parking Brake Warning Light -Kt 01048 Diesel Electronic Warning Light -K104 01049 Supply Voltage (Terminal 50) 01050 Glow Plug Status Monitoring 01051 Fuel MC Positioning Motor -V117 01052 Throttle Position Sensor -G157 01053 Injection Start-valve -N182 01054 Power Supply Relay (Terminal 30) -J317 01055 Injection Start-sensor -G158 01057 Function - Constant Charge - Voltage 01058 Function - Constant Charge - Current 01059 Rotor Position Sensor -G159 01060 Ignition Coil Lower Temperature Sensor -G160 01061 gnition Coil Upper Temperature Sensor -G161 01070 Starter Relay -J53 01071 Clutch Pedal Position Sensor -G162 01072 Clutch Position - Vacuum Valve -N183 01073 Clutch Pressure System 01074 Clutch Position - Vent Valve 01075 Vacuum Pump Relay -J320 01076 Hydraulic Pump Clutch Relay -J319 01077 Brake Booster Vacuum Switch -F190 01078 TR Gear Selector Switch -F191 01079 Power Steering Relay -J320 01080 Power Steering Pressure Switch -F192 01081 Priority Switch Valve -N185 01082 Low Fuel Level Warning Light -K105 01083 Low Windshield Fluid -Windshield Fluid Indicator Light or Sensor -K106 01084 32oF (0o) Freeze Temperature Warning Light -K107 01085 39oF (4o) Temperature Warning Light -K108 01086 Speedometer - Vehicle Speed Sensor -G22 01087 Basic Setting Not Performed 01088 Mixture Control Adjustment 2 01089 Tensioning Bow Raised Position Switch -F204 01090 Tensioning Bow Stowed Position Switch -F203 01091 Convertible Top Closed Position Switch -F202 01092 Convertible Top Open Position Switch -F171 01093 Compartment Cover Open Position Switch -F201 01094 Compartment Cover Left Switch 3-F195 01095 Compartment Cover Unlocked Left Switch 2-F197 01096 Comportment Cover Locked Left Switch 1-F199 01097 Convertible Top Front Lock Switch -F172 01098 Trunk Lid Closed Position Switch -F206 01099 Luggage Compartment Switch (Locked) 01100 Luggage Compartment Switch (Unlocked) 01101 Convertible Top Latch Open Position Switch -F205 01102 Compartment Cover Right Switch 3-F196 01103 Compartment Cover Unlocked Right Switch 2-F198 01104 Compartment Cover Locked Right Switch 1-F200 01105 Solenoid Valve 8-N186 01106 Power Window Opening Relay -J291 01107 Convertible Top Locked Indicator Light -K98 01108 Power Window Closing Relay -J292 01109 Convertible Top Hydraulic Pump Relay -J321 01110 Convertible Top Unlocking Solenoid -N187 01111 Luggage Compartment Lock Actuator Motor 1 01112 Actuator Motor 1 and 2 Power Supply 01113 Luggage Compartment Lock Actuator Motor 2 01114 Parking Brake Warning Light Switch -F9 01115 Just 3 Byte Space 01116 Convertible Top Unlocking Actuator Motor 01117 Generator Terminal DF Load Signal 01118 Engine Pre-heating Circuit 01119 Transmission Shift-Range Gear Position Signal 01120 Camshaft Adjustment 1 01121 Camshaft Adjustment 2 01122 Camshaft Position Sensor 2-G163 01123 Triggering Faulty 01124 Charge Time Status Monitoring 01125 Intake Manifold Change-over 01126 Engine Speed Signal 01127 Reserve Fuel Indicating Lamp 01128 Anti-theft System -Immobilizer Sensor -D2 01129 S-terminal -H15 01130 ABS Operation - Signal outside range of tolerance 01131 Blinking Light Activation 01132 Front Infrared Sensor -G166 01133 Rear Infrared Sensor -G167 01134 Alarm Horn -12 01135 Vehicle Interior-motion Sensor 01136 Engine Start Interrupt 01137 Central Locking Contact Switch 01138 Central Locking - Drivers Door Unlock 01139 Central Locking - Passenger Door Unlock 01140 Central Locking - Trunk Lid Unlock 01141 Trunk Lid Release Switch Motor 01142 Central Locking - Unlocking Motor 01143 Central Locking - Opening Motor 01144 Central Locking - Opening Motor 01145 Central Locking - Opening Motor 01146 Central Locking - Closing Motor 01147 Central Locking - Trunk Lid Release Motor -V120 01148 Save Fuse Door - Activation 01149 Save Fuse Door - Deactivating 01150 Analog Indicator 01151 Diesel Engine Safety Switch -F207 01152 TR Gear Monitoring Switch -F209 01153 E-(Economic) Switch - E163 01154 Clutch System Pressure Switch -F210 01155 Clutch, Mechanics 01156 TR Gear Recognition Switch -F208 01157 Alarm Horn Voltage Supply 01158 Turn Signal Voltage Supply 01159 Save Fuse Wiring 01160 Coolant Glow Plug Relay -J325 01165 Throttle Body Control Module -J338 01166 Engine Torque Signal 01167 Wide Open Throttle Stop - Throttle Stop Valve -N194 01168 Idle Rpm Increase Valve -N177 01169 Door Contact Switch - Driver Side -F2 01170 Fuel Injection Duration Sensor -G175 01172 Seat Heating Temperature Sensor -Driver Side -G59 01173 Longitudinal Adjustment Motor -Driver Side -V28 01174 Height Seat Adjustment - Driver Side -V38 01175 Heated Seat Adjustment - Driver Side - E94 01176 Key Faulty 01177 Engine Control Unit 01179 Incorrect Key Entry 01180 Engine / A/C - Electrical Connection 01181 Initializing - Only 2 Keys Pressed 01182 Height Adaptation 01183 Catalytic Convertor Warning Lamp -K72 01184 Outlet Temperature Sensor -G174 01185 Fresh Air Blower - Rear -V80 01186 Rear Air Distribution Servo Motor -V136 01187 Rear Temperature Flap Servo Motor -V137 01188 Control Module Solenoid - Electrical Connector 01190 Control Module Actuator Motor - Electrical Connector 01192 Torque Converter Clutch 01193 Low Heat Output -J359 01194 High Heat Output -J360 01196 Engine/Transmission Can Bus 01197 Engine/Transmission Can Bus -Wire-A 01198 Engine/Transmission Can Bus -Wire-B 01199 Engine/ABS Electrical Connection 01200 ABS Valves Voltage Supply -Fuse S54 01201 ABS Pump Voltage Supply -Fuse S53 01202 Diagnostic Wire 01208 Data Record Changes -VIN 01235 Secondary Air Injection - Solenoid Valve -N112 01236 Shift-Lock Solenoid -N110 01237 Fuel Cut-off Valve -N109 01238 Ignition Timing (Spark Angle) Control 01239 Throttle Position Actuator Vent Valve -N97 01240 Throttle Position Actuator Breather Valve -N117 01241 EVAP Canister Purge Solenoid Valve -N115 01242 Final Stage in Control Unit 01243 Intake Manifold Change-over Valve -Nix 01244 Heating Oxygen Sensor Control Module -J208 01245 Differential Pressure Regulator -N73 01246 Early Fuel Evaporation Relay -J81 01247 EVAP Canister Purge Regulator Valve -N80 01248 Wide Open Throttle Enrichment Two-way Valve -N54 01249 P0201 Cylinder 1 - Injector Fault -N30 01250 P0202 Cylinder 2 - Injector Fault -N31 01251 P0203 Cylinder 3 - Injector Fault -N32 01252 P0204 Cylinder 4 - Injector Fault -N33 01253 P0205 Cylinder 5 - Injector Fault -N83 01254 P0206 Cylinder 6 - Injector Fault -N84 01255 P0207 Cylinder 7 - Injector Fault -N85 01256 P0208 Cylinder 8 - Injector Fault -N86 01257 Idle Air Control Valve -N71 01258 Air Flap Positioner -V63 01259 Fuel Pump Relay Circuit -J17 01260 Deceleration Fuel Cut-off Valve -N55 01261 Oxygen Sensor Frequency Valve -N7 01262 Wastage Bypass Regulator Valve -N75 01263 Cold Start Injector -N17 01264 Secondary Air Injection Pump Relay -J299 01265 EGR Vacuum Regulator Solenoid Valve -N18 01266 Glow Plug Relay -J52 01267 Automatic Glow Time Control Unit -J179 01268 Quantity Adjuster -N146 01269 Injection Start Valve -N108 01270 A/C Compressor Clutch -N25 01271 Temperature Regulator Flap Motor -V68 01272 Central Air Flap Motor -V70 01273 Fresh Air Blower - V2 01274 Air Flow Flap Motor -V71 01275 Solenoid Relay 01276 ABS Hydraulic Pump - V64 01277 ABS Hydraulic Pump Relay -J185 01278 Electronic Differential Lock Cut-off Relay -J263 16486 P0102 Mass or Volume Air Flow Circuit - Low input 16487 P0103 Mass or Volume Air Flow Circuit - High Input. May be due to a low battery if found with 17988 (P1580) 16496 P0112 IAT Sensor - Temp High -Circuit Low - G42 16497 P0113 IAT Sensor - Temp Low - Circuit High - G42 16500 P0116 Engine Coolant Temperature Circuit -Range/Performance Problem 16501 P0117 Engine Coolant Temperature Circuit -Low Input (High Temp) 16502 P0118 Engine Coolant Temperature Circuit -High Input (Low Temp) 16504 P0120 Throttle Position Sensor A -Circuit Malfunction 16505 P0121 Throttle Position Sensor A -Circuit - Performance Problem -Out of Range 16506 P0122 Throttle Position Sensor A Circuit -Low Voltage Input 16507 P0123 Throttle Position Sensor A Circuit -High Voltage Input 16509 P0125 Cooling System -Temp Too Low to Enter Closed Loop - G62 16514 P0130 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 1) 16515 P0131 O2 Sensor Circuit - Voltage Low (Bank 1 Sensor 1) 16516 P0132 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 1) 16517 P0133 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 1) 16518 P0134 O2 Sensor Circuit - No Activity Detected (Bank 1 Sensor 1) 16519 P0135 O2 Sensor Heater Circuit -Malfunction (Bank 1 Sensor 1) 16520 P0136 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 2) 16521 P0137 O2 Sensor Circuit - Low Voltage (Bank 1 Sensor 2) 16522 P0138 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 2) 16524 P0140 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 2) 16525 P0141 O2 Sensor Heater Circuit -Malfunction (Bank 1 Sensor 2) 16534 P0150 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 1) 16536 P0152 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 1) 16537 P0153 O2 Sensor Circuit - Slow Response (Bank 2 Sensor 1) 16538 P0154 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 1) 16539 P0155 O2 Sensor Heater Circuit -Malfunction (Bank 2 Sensor 1) 16540 P0156 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 2) 16542 P0158 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 2) 16543 P0159 O2 Sensor Circuit - Slow Response (Bank 2 Sensor 2) 16544 P0160 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 2) 16545 P0161 O2 Sensor Heater Circuit -Malfunction (Bank 2 Sensor 2) 16554 P0170 Fuel Trim -Malfunction (Bank 1) 16555 P0171 Fuel Trim -System Lean (Bank 1) 16556 P0172 Fuel Trim -System Rich (Bank 1) 16557 P0173 Fuel Trim -Malfunction (Bank 2) 16558 P0174 Fuel Trim -System Lean (Bank 2) 16559 P0175 Fuel Trim -System Rich (Bank 2) 16684 P0300 Random Misfire Detected -Any Cylinder 16685 P0301 Cylinder #1 -Misfire Detected 16686 P0302 Cylinder #2 -Misfire Detected 16687 P0303 Cylinder #3 -Misfire Detected 16688 P0304 Cylinder #4 -Misfire Detected 16689 P0305 Cylinder #5 -Misfire Detected 16690 P0306 Cylinder #6 -Misfire Detected 16691 P0307 Cylinder #7 -Misfire Detected 16692 P0308 Cylinder #8 -Misfire Detected 16706 P0322 Ignition/Distributor Engine Speed Input Circuit - No Signal 16711 P0327 Knock Sensor #1 Circuit - Low Input (Bank 1 or Single Sensor) 16716 P0332 Knock Sensor #2 Circuit - Low Input (Bank 2) 16721 P0337 Crankshaft Position Sensor Circuit - Low Input 16725 P0341 Camshaft Position Sensor Circuit - Out of Range/Performance 16784 P0400 Exhaust Gas Recirculation (EGR) -Flow Malfunction 16785 P0401 Exhaust Gas Recirculation (EGR) -Flow Insufficient 16786 P0402 Exhaust Gas Recirculation (EGR) -Flow Excessive 16795 P0411 Secondary Air Injection System (B2) - Incorrect Flow 16806 P0422 Main Catalyst Efficiency - Below Threshold (Bank 1) 16816 P0432 Main Catalyst Efficiency - Below Threshold (Bank 2) 16824 P0440 Evaporative Emission Control System (EVAP) -Purge Malfunction 16825 P0441 Evaporative Emission Control System -Incorrect Purge Flow 16826 P0442 Evaporative Emission Control System -Leak Detected (small leak) 16836 P0452 Evaporative Emission Control System -Pressure Sensor - Low Input 16837 P0453 Evaporative Emission Control System -Pressure Sensor - High Input 16839 P0455 Evaporative Emission Control System -Leak Detected (gross leak) 16845 P0461 Fuel Level Sensor Circuit - Range/Performance 16885 P0501 Vehicle Speed Sensor -Range/Performance 16890 P0506 Idle Control Module - RPM Lower Than Expected 16891 P0507 Idle Control Module - RPM Higher Than Expected 16894 P0510 Throttle Position Sensor -Closed Switch 16989 P0605 Internal Control Module Read Only Memory (EPROM) Error 17090 P0706 Transmission Range Sensor Circuit -Range/Performance 17091 P0707 Transmission Range Sensor Circuit -Low Input 17509 P1101 O2 Sensor Circuit (B1-S1) Voltage Too Low/Air Leak 17510 P1102 O2 Sensor Circuit Heating Circuit (B1-S1) -Short to B+ 17511 P1103 O2 Sensor Circuit Heating Circuit (B1-S1) -Output Too Low 17512 P1104 O2 Sensor Circuit (B1-S2) Voltage Too Low - Air Leak 17513 P1105 O2 Sensor Circuit Heating Circuit (B1-S2) -Short to B+ 17514 P1106 O2 Sensor Circuit (B2-S1) Voltage Too Low - Air Leak 17515 P1107 O2 Sensor Circuit Heating Circuit (B2-S1) -Short to B+ 17516 P1108 O2 Sensor Circuit Heating Circuit (B2-S1) -Output too Low 17517 P1109 O2 Sensor Circuit (B2-S2) Voltage Too Low - Air Leak 17518 P1110 O2 Sensor Circuit Heating Circuit (B2-S2) -Short to B+ 17535 P1127 Long Term Fuel Trim -System too Rich (Bank 1) 17536 P1128 Long Term Fuel Trim -System too Lean (Bank 1) 17609 P1201 Cylinder #1 Fuel Injector Circuit - Electrical Malfunction 17610 P1202 Cylinder #2 Fuel Injector Circuit - Electrical Malfunction 17611 P1203 Cylinder #3 Fuel Injector Circuit - Electrical Malfunction 17612 P1204 Cylinder #4 Fuel Injector Circuit - Electrical Malfunction 17613 P1205 Cylinder #5 Fuel Injector Circuit - Electrical Malfunction 17614 P1206 Cylinder #6 Fuel Injector Circuit - Electrical Malfunction 17615 P1207 Cylinder #7 Fuel Injector Circuit - Electrical Malfunction 17616 P1208 Cylinder #8 Fuel Injector Circuit - Electrical Malfunction 17621 P1213 Cylinder #1 Fuel Injector Circuit - Short to B+ 17622 P1214 Cylinder #2 Fuel Injector Circuit - Short to B+ 17623 P1215 Cylinder #3 Fuel Injector Circuit - Short to B+ 17624 P1216 Cylinder #4 Fuel Injector Circuit - Short to B+ 17625 P1217 Cylinder #5 Fuel Injector Circuit - Short to B+ 17626 P1218 Cylinder #6 Fuel Injector Circuit - Shod to B+ 17627 P1219 Cylinder #7 Fuel Injector Circuit - Shod to B+ 17628 P1220 Cylinder #8 Fuel Injector Circuit - Shod to B+ 17633 P1225 Cylinder #1 Fuel Injector Circuit - Short to Ground 17634 P1226 Cylinder #2 Fuel Injector Circuit - Short to Ground 17635 P1227 Cylinder #3 Fuel Injector Circuit - Short to Ground 17636 P1228 Cylinder #4 Fuel Injector Circuit - Short to Ground 17637 P1229 Cylinder #5 Fuel Injector Circuit - Short to Ground 17638 P1230 Cylinder #6 Fuel Injector Circuit - Short to Ground 17639 P1231 Cylinder #7 Fuel Injector Circuit - Short to Ground 17640 P1232 Cylinder #8 Fuel Injector Circuit - Short to Ground 17645 P1237 Cylinder #1 Fuel Injector Circuit - Open Circuit 17646 P1238 Cylinder #2 Fuel Injector Circuit - Open Circuit 17647 P1239 Cylinder #3 Fuel Injector Circuit - Open Circuit 17648 P1240 Cylinder #4 Fuel Injector Circuit - Open Circuit 17649 P1241 Cylinder #5 Fuel Injector Circuit - Open Circuit 17650 P1242 Cylinder #6 Fuel Injector Circuit - Open Circuit 17651 P1243 Cylinder #7 Fuel Injector Circuit - Open Circuit 17652 P1244 Cylinder #8 Fuel Injector Circuit - Open Circuit 17656 P1250 Fuel Level Too Low 17733 P1325 Cylinder #1 Knock Control Limit Attained 17734 P1326 Cylinder #2 Knock Control Limit Attained 17735 P1327 Cylinder #3 Knock Control Limit Attained 17736 P1328 Cylinder #4 Knock Control Limit Attained 17737 P1329 Cylinder #5 Knock Control Limit Attained 17738 P1330 Cylinder #6 Knock Control Limit Attained 17739 P1331 Cylinder #7 Knock Control Limit Attained 17740 P1332 Cylinder #8 Knock Control Limit Attained 17747 P1339 Crankshaft Position/Engine Speed Sensors Cross connected 17748 P1340 Camshaft/Crankshaft Position Sensors (B2) -Out of Sequence 17749 P1341 Ignition Coil Power Output Stage #1 -Short to Ground 17751 P1343 Ignition Coil Power Output Stage #2 -Short to Ground 17753 P1345 Ignition Coil Power Output Stage #3 -Short to Ground 17799 P1391 Camshaft Position Sensor (B2) -Short to Ground 17800 P1392 Camshaft Position Sensor Open (B2) - Short to B+ 17801 P1393 Ignition Coil Power Output Stage #1 -Electrical Malfunction 17802 P1394 Ignition Coil Power Output Stage #2 -Electrical Malfunction 17803 P1395 Ignition Coil Power Output Stage #3 -Electrical Malfunction 17804 P1396 Engine Speed Sensor -Missing Tooth 17808 P1400 EGR Valve Circuit - Electrical Malfunction 17809 P1401 EGR Valve Circuit - Power Stage Short to Ground 17810 P1402 EGR Valve Circuit - Short to B+ 17815 P1407 EGR Temperature Sensor -Signal too Low 17816 P1408 EGR Temperature Sensor -Signal too High 17817 P1409 Tank Ventilation Valve - Electrical Malfunction 17818 P1410 Tank Ventilation Valve - Short to B+ 17819 P1411 Secondary Air Injection System (B2) - Restricted Flow 17822 P1414 Secondary Air Injection System (B2) - Leak Detected 17826 P1418 Fuel Level Sensor -Signal too High 17828 P1420 Secondary Air Injection System Control Module -Electrical Malfunction 17829 P1421 Secondary Air Injection System Control Valve Circuit - Short to Ground 17830 P1422 Secondary Air Injection System Control Valve Circuit - Short to B+ 17831 P1423 Secondary Air Injection System (B1) - Flow too Low 17832 P1424 Secondary Air Injection System (B1) - Leak Detected 17833 P1425 Tank Ventilation Valve - Short to Ground 17834 P1426 Tank Ventilation Valve - Open Circuit 17842 P1434 Secondary Air Injection System Pump Relay Circuit - Short to B+ 17844 P1436 Secondary Air Injection System Pump Relay Circuit - Electrical Malfunction 17848 P1440 EGR Valve Circuit - Power Stage Open 17858 P1450 Secondary Air Injection System Pump Relay Circuit - Short to B+ 17859 P1451 Secondary Air Injection System Pump Relay Circuit - Short to Ground 17860 P1452 Secondary Air Injection System Pump Relay Circuit - Open Circuit 17878 P1470 EVAP Emission Control System L.D.P Circuit -Malfunction 17879 P1471 EVAP Emission Control System L.D.P. Circuit - Short to B+ 17883 P1475 EVAP Emission Control System L.D.P. - Malfunction Signal Circuit open 17884 P1476 EVAP Emission Control System L.D.P. - Malfunction/Insufficient Vacuum 17908 P1500 Fuel Pump Relay Circuit - Electrical Malfunction 17910 P1502 Fuel Pump Relay Circuit - Short to B+ 17912 P1504 Intake Air System Bypass Air Determined 17913 P1505 CTP Switch not Closing -Open Circuit 17914 P1506 CTP Switch not Opening -Short to Ground 17917 P1509 IAC Circuit -Electrical Malfunction 17918 P1510 IAC Circuit -Short to B+ 17919 P1511 Intake Manifold Changeover Valve Circuit -Electrical Malfunction 17920 P1512 Intake Manifold Changeover Valve Circuit -Short to B+ 17951 P1543 Throttle Actuation Potentiometer -Signal too Low 17952 P1544 Throttle Actuation Potentiometer -Signal too High 17988 P1580 Throttle Actuator (B1) Fault - May be caused by low battery if found with 16487 (P0103) 17990 P1582 Idle Adaption at Limit 18008 P1600 Power Supply (B+) Terminal 15 -Low Voltage 18010 P1602 Power Supply (B+) Terminal 30 -Low Voltage 18014 P1606 Rough Road Spec. Engine Torque ABS-SG - Electrical Malfunction 18019 P1611 MIL Call-up Circuit/Transmission Control Module - Short to Ground 18020 P1612 ECM - Incorrectly Coded 18021 P1613 MIL Call-up -Circuit Open or Short to B+ 65535 P0603 Control Unit Failure or Internal Control Module Keep Alive Memory (KAM) Error or Power Failure to Control Unit or Bad Ground Contacts or No Faults Recorded (If MIL Not Illuminated) 65535 No Faults Recorded (If MIL Not Illuminated) 65535 Control Unit Faulty (In Some Systems) P0217 Temp Light -Engine Hot P0218 Temp Light -Transaxle Hot P0326 Knock Sensor - Constant Knock P0351 Ignition -Faulty P0352 Ignition -Faulty P0420 Converter -Low Efficiency P0443 EVAP Purge - Circuit Fault P0500 VSS Sensor - No Signal P0560 Battery Voltage - Out of Range P0561 Battery Voltage - Unstable P0562 Battery Voltage - Low P0563 Battery Voltage - High P0565 Cruise Control -Circuit Fault P0571 Brake Switch -Circuit Fault P0572 Brake Switch -Low Voltage P0573 Brake Switch -High Voltage P0600 PCM -No Serial Data P0601 EPROM - Fault P0602 PCM Program - Fault P0604 PCM RAM Memory -Fault P0606 PCM Processor - Fault P1782 Engine/Transmission Data Electrical Connection Ignition Intervention. Also check for loose ECM power relay. Link to comment Share on other sites More sharing options...
fransisaudi Posted May 6, 2012 Share Posted May 6, 2012 Hey Admin, Thats a big bunch of useful codes you listed. Thanks a ton. Link to comment Share on other sites More sharing options...
