How can i change the rear speakers.
  • 1 year later...
To remove the rear speakers is a big job because it solely depends upon how the rear speakers are fixed in the car. If it is permanently fixed with the bolts, then its better you take professional's help. But if you the rear speakers are only assigned to the rear dashboard, then you can remove it on your own. Just make sure that you don't destroy the wires as they are delicate. After detaching it, you can assign your new speakers and connect the wires back. I hope the information is helpful for you. ;):)
