ansaari Posted December 24, 2010 Share Posted December 24, 2010 i have got my Q7 2008 tiers inflated with nitogen when the beeping started thatthe tier presurre was low but it still had oxygen so i slightly mixed it the beeping still cont. is it OK to mix oxygen and nitrogen? And also how can i stop the beeping when my car Link to comment Share on other sites More sharing options...
carter Posted January 2, 2011 Share Posted January 2, 2011 MIxing is not recommended. Better empty full tyre and re inflate with either one. Secondly keep the car running so that TPMS (Tyre Pressure monitoring system) can judge the change and stop beeping after you finish. Link to comment Share on other sites More sharing options...
armaan Posted January 30, 2011 Share Posted January 30, 2011 nitro is good for this hot country climate, as it doesn't allow tires to heat up and provide extra life and safety from bursting (if overheated) Link to comment Share on other sites More sharing options...
sami Posted February 27, 2011 Share Posted February 27, 2011 Its a crap for taking money out of ur pocket. Since decades ppl using normal air with normal tire and last for 3-5 years easy. Bursting happen if u drive at 20psi at 120kmp for 2 hrs. If tire pressure is checked every week and changed every 3 years - 5 years you will never have bursting tire due to overheating the rubber. Link to comment Share on other sites More sharing options...
