gerywar Posted May 26, 2011 Share Posted May 26, 2011 my engine is missing and i will appreciate if someone can tell me the reasons for this. thanks Link to comment Share on other sites More sharing options...
screamer Posted May 28, 2011 Share Posted May 28, 2011 Check the spark plug, ignition coil and plug wire from outside first if its having some problem then fix it. (external issues) If they all are fine then get the engine compression test done and see which cylinder is having low pressure and that cylinder is having stuck valves, injector or lifter/rocker there. (Internal issues) Link to comment Share on other sites More sharing options...
