goldust2012 Posted August 7, 2012 Share Posted August 7, 2012 I was driving my Santa Fe on Jabal-e-Shams Oman. I used AWD lock and put my car in 1st gear (not in D mode). In a sharp steep ramp when the car was going down, RPM reached at 5.5 but the speed was under control only at 25 to 30. When I move gear to 2, the speed reached at 80-90 but RMP was at normal. I used heavy breaks to reduce speed. Is it OK to drive at 5.5 RMP? What will be the effect on engine? Link to comment Share on other sites More sharing options...
lutfi Posted August 8, 2012 Share Posted August 8, 2012 RPM increase to 5.5k as u were on first gear and steep downhill. First gear top speed is 10-20 kmph and if you exceeding this then obviously RPM will increase. But in steep downhill situation you should do that only. Let RPM rev to high but you will be safe than getting out of control. And once in a while if RPM toches to 5k its ok. Next time in same situation you can use brake little bit too to keep RPM under 5k which will use engine braking power, gear braking power and ur foot brakes so the load will be equally distributed and more efficient. Link to comment Share on other sites More sharing options...
edison Posted August 26, 2012 Share Posted August 26, 2012 down hill or uphill if you have divine this long then i suggest you get the brakes changed as soon as possible. Link to comment Share on other sites More sharing options...
goldust2012 Posted August 27, 2012 Author Share Posted August 27, 2012 Dear Edison, My question is different. Link to comment Share on other sites More sharing options...
hameed Posted August 27, 2012 Share Posted August 27, 2012 Is it OK to drive at 5.5 RMP? What will be the effect on engine? Answer: Yes its ok to drive at 5500 RPM, Long stretch driving at 5500 rpm over 10 mins will reduce the engine life due to component wear and tear. But occasional short use doesn't bother engine at all. Link to comment Share on other sites More sharing options...
