sadiq Posted March 1, 2014 Report Share Posted March 1, 2014 Hey Guys Just had a curious question. How do we replace oxygen sensor from the car! I want to replace from my Coupe but no idea how to do that! Suggestions Please. Link to comment Share on other sites More sharing options...
nackjack Posted March 2, 2014 Report Share Posted March 2, 2014 Firstly, disconnect the connection from the oxygen sensor and then unscrew the sensor from the exhaust pipe. Compare the new oxygen sensor to the old one and make sure that the extension is same, otherwise you won't be able to screw the new oxygen sensor into the exhaust pipe. After fixing it, just ignition to your car. If your car starts without any trouble, it means you safely replaced the oxygen sensor. Link to comment Share on other sites More sharing options...
hamadi Posted March 15, 2014 Report Share Posted March 15, 2014 Just one suggestion. If you have never done that on your own, better take a help from an expert who has changed the oxygen sensor before. Otherwise it may be difficult for you. If in case, any fault pops up then you might end up destroying the sensor. Link to comment Share on other sites More sharing options...
sadiq Posted March 26, 2014 Author Report Share Posted March 26, 2014 Thanks guys. I tried to do it as you suggested. At first, I couldn't understand the procedure, but then after connecting the sensor in the exhaust pipe, everything was simple. Thank you Link to comment Share on other sites More sharing options...
