mithras Posted June 15, 2011 Share Posted June 15, 2011 dose the tier pressure depend on the tier that i am using or the weight of my car. how will i know the best PSI for the tiers please help Link to comment Share on other sites More sharing options...
sharmaa Posted June 26, 2011 Share Posted June 26, 2011 If you using the OEM spec tires that comes with your car (refer to manual) then use the OEM specified tire pressure. If little plus minus size then also stick to OEM specification on tire pressure. If huge variance then refer to tire spec and make sure you inflate the under MAX pressure written on tire. Usually OEM is 30 PSI - 35 PSI in all 4 tires. Link to comment Share on other sites More sharing options...
mithras Posted June 27, 2011 Author Share Posted June 27, 2011 thanks for the reply Link to comment Share on other sites More sharing options...
