KiaDxb Posted May 22, 2011 Share Posted May 22, 2011 do i need steering oil change??? the reason i am asking this is because the steering seems to be a bit rough Link to comment Share on other sites More sharing options...
KiaDxb Posted May 24, 2011 Author Share Posted May 24, 2011 Steering oil also known as PSF (Power Steering Fluid) usually need a top up after sometime. Change is required in major service of 40k kms. Check the level and top up to see if it helps, then change the whole fluid. If still same that means your steering pump must be dying. Link to comment Share on other sites More sharing options...
