KiaDxb Posted May 24, 2011 Share Posted May 24, 2011 i am the owner if 2006 Kia Sportage and i am getting my timing belt changed but the this is that i cant remove the timing belt drive sprocket from the harmonic balancer as it is attached to it. how do i do that Link to comment Share on other sites More sharing options...
KiaDxb Posted May 26, 2011 Author Share Posted May 26, 2011 Avoid using puller as they won't work on these ones. The outer part is bonded to the inner. The pulley won't come off due to the timing sprocket and crank pulley sticking together. The best way I have found to get the pulley off is to spray penetrating oil where the timing sprocket roll pin enters the crank pulley, and also into the contact surface where the crankshaft contacts the pulley. Let it sit for a while. Try working the pulley side to side (by grabbing it with both hands on opposite sides, pull with one hand and push with the other). Sometimes this is enough. If not, I use a hammer and a thick brass punch, I'll tap on the center metal portion of the pulley at alternating points (12 then 6, 3 then 9, and so on). Between these two methods, it will come out for sure. Link to comment Share on other sites More sharing options...
KiaDxb Posted June 19, 2011 Author Share Posted June 19, 2011 thanks bro. really appreciate the idea Link to comment Share on other sites More sharing options...
