defender Posted April 27, 2011 Share Posted April 27, 2011 Hi evry one, any body know wher i can find Manual gearbox oil for defender in UAE i think have same qualification of 75w 80 Link to comment Share on other sites More sharing options...
Macrover Posted May 9, 2011 Share Posted May 9, 2011 BMW and Honda dealers will stock MTF94 MTF94 is a long life version of 10W40 Surely MTF-94 is a 75W80 viscocity oil to API GL-4. Castrol VMX-S is a semi synthetic 75W80 whereas Texaco MTF-94 is fully synth 75W80. They are both semi synthetic - a fully synthetic version is Castrol SMX-S SAE 75-85, API GL3/4. Pricey, but works well in the PG1 tranny. MTF94 is indeed an equivalent to a 75w/80 which is why refilling with a 10w/40 oil will give you a slicker and lighter change. Change it every 50K is all you need to do. The MTF94 has a recommended change of 120K but from experience 50K of MTF94 in an gearbox is enough to give a heavy gear change. Link to comment Share on other sites More sharing options...
defender Posted May 25, 2011 Author Share Posted May 25, 2011 thanks a lot bro ii will try to find it in local market Link to comment Share on other sites More sharing options...
qvzd02 Posted December 14, 2011 Share Posted December 14, 2011 Texaco were the manufacturers of original fill oil for British built Honda gearboxes fitted to MG/Rover/Austin cars from the early 80's. There is nothing new or mysterious about the oil. FWIW I have used MT type oil in my LT77 gearbox for over 15 years and long before LR decided it was a superior product. It still goes as well as ever after over 10,000 hours of intense use. I have never used the specific MTF [belatedly] recommended by LR but use MT oil specific for Ford MT75 [i think it's called] made by Morris oils so as far as I am concerned the brand is not important as long as it is reputable while the spec is most important but not life threatening as long as it is better than ATF, which LR recommended for many years and which provided little wear protection over the long term. Link to comment Share on other sites More sharing options...
nutbolt Posted February 13, 2012 Share Posted February 13, 2012 Intersting info qvzd02 Link to comment Share on other sites More sharing options...
