Why is there water on the passenger side of Freelander?
Couple of possibilities, if you have washed it recently then it could be a door seal or sunroof seal, if not related to washing it then your heater matrix is leaking and needs to be replaced which is a big job and can be expensive, if your not bothered about the heater working then the water pipes under the hood can be disconnected and you will have no more problems
