gohannessian Posted January 9, 2013 Report Share Posted January 9, 2013 Hi guys, About 6 months in with my new 2004 Disco and when I am stopped at a red light with auto tranny in drive there is a grinding (almost diesel) sound coming from under the truck. It seems to be from the tranny/t-case area. When I put the transmission into neutral the grinding stops. I would guess it's a t-case issue but any hints or guesses that you may have could help me heaps. Trying to figure out how hard this is going to hit me in the wallet... Thanks folks! edit: I have crawled under and neither driveshaft is turning when vehicle is stopped in drive. I have scoured other forums and that seems to be the main culprit, which makes my problem all the more perplexing to me. Link to comment Share on other sites More sharing options...
jamalautoworks Posted January 10, 2013 Report Share Posted January 10, 2013 hi, check your mountings, for gear and engine, if its ok, then need to diagnose further like fly wheel, or internal components depending upon the noise, Link to comment Share on other sites More sharing options...
JohnT Posted January 12, 2013 Report Share Posted January 12, 2013 Drive shaft moves when vehicle moves, and hence its not driveshaft noise as it usually comes at 50 kmph with slight vobling. This could be some engine or gear foundation (as jamal said) weak or completely torn. In this case you will usually have vibration but not grinding noise, can you confirm if its grinding noise or slight vibration you meant to say? Depending on which foundation is faulty its couple of hundred job not much. My advise if one engine mount is faulty change all, or else soon you will change another one. Engine has 3 mounts and gear has 2 mounts, each cost around 100 dhs plus labor could be 100 - 200 dhs for changing all. Link to comment Share on other sites More sharing options...
gohannessian Posted January 14, 2013 Author Report Share Posted January 14, 2013 John and Jamal, thank you both very much! Seems as though there is in fact one engine mount that has sheared! Now the adventure begins to find a garage for my first repair. Any trusted places that do good work and won't try to overcharge? Is AAA pretty fair on things like this? Thanks again, guys. Link to comment Share on other sites More sharing options...
gohannessian Posted March 17, 2013 Author Report Share Posted March 17, 2013 Hi guys, Just wanted to close this thread with a follow up. The clanking noise was, in fact, a very worn engine mount that I had replaced at AAA this week. Also took care of my front driveshaft that was hanging on by a thread. Thanks for all of your help, Greg Link to comment Share on other sites More sharing options...
