leejon Posted April 5, 2012 Share Posted April 5, 2012 the headlights come on and sometimes it dose not as this is a strange problem i am hoping to got some good advise as to where i start looking for. thanks Link to comment Share on other sites More sharing options...
vikramad Posted April 13, 2012 Share Posted April 13, 2012 Look with loos / half burnt fuse and loose wiring first. It could be loose headlamp too if one of them is not getting on at times. If both not switching on at same time, then its more fundamental issue of fuses/wiring/switch itself. Good luck and drive safe. Link to comment Share on other sites More sharing options...
mazharudin Posted April 27, 2012 Share Posted April 27, 2012 It is possible that there is a loose wiring somewhere that is why it goes on and off. You might want to start with the LKM light switch and check to see if the wires connected there are disconnected. Link to comment Share on other sites More sharing options...
ClearSky Posted May 11, 2012 Share Posted May 11, 2012 There could be a loose wire somewhere on your system...or you could just have a light sensitive system that comes on when it gets dark. Make sure your headlight function is turned to autostart. Link to comment Share on other sites More sharing options...
