adamd Posted July 17, 2012 Share Posted July 17, 2012 there is a small light on the doors that is not working and i dont even know if its the lamp or anything else that is not working. How can i find out is there some tool like a tester tool that i can use? Link to comment Share on other sites More sharing options...
manshor Posted July 19, 2012 Share Posted July 19, 2012 if you go to car shops they can change the bulb for you. Link to comment Share on other sites More sharing options...
berg Posted July 30, 2012 Share Posted July 30, 2012 if you check fuse box then you will see a fuse for them check if they are working Link to comment Share on other sites More sharing options...
yaari Posted August 6, 2012 Share Posted August 6, 2012 My brothers car had a similar situation what he got done is remove the door panel and got the wire checked which he found was faulty so he got the wiring changed and the bulb was working good so it was fixed at much cheaper rate as what was expected. Link to comment Share on other sites More sharing options...
jeer Posted October 30, 2012 Share Posted October 30, 2012 did you know that each bulb costs 250 Dhs. Original ones. Anyone looking for cheaper option. Link to comment Share on other sites More sharing options...
rohitsr Posted November 5, 2012 Share Posted November 5, 2012 why parts here are so expensive and not the car? Link to comment Share on other sites More sharing options...
adamd Posted November 26, 2012 Author Share Posted November 26, 2012 had to go the the dealers workshop and they replaced the bulbs. Link to comment Share on other sites More sharing options...
rohitsr Posted February 11, 2013 Share Posted February 11, 2013 why you went to the dealer? didnt you find the bulb form elsewhere? Link to comment Share on other sites More sharing options...
