mmkenon Posted September 7, 2011 Share Posted September 7, 2011 How do i clean the fuel tank of my Mazda 3. a step procedure will be helpful. Thanks Link to comment Share on other sites More sharing options...
majeed Posted September 12, 2011 Share Posted September 12, 2011 There is a liquid solution available in the market so purchase that and there are instructions on it. Link to comment Share on other sites More sharing options...
harryh Posted September 27, 2011 Share Posted September 27, 2011 Ordinarily, the best way to keep a fuel tank clean is by using a bottle of fuel stabilizer/liquid as suggested by Majeed. However, you may alternatively do a thorugh cleaning job by following the steps as detailed below a.Consult your vehicle's manual to understand how each part connects to the tank and how the gas tank should be removed. b.Make sure there is little to no gas in the car. Drive your car to burn any remaining gas, if necessary. c.Remove the tank, based on the instructions in the car's manual. Make sure that your tank is empty. d.Fill the tank with fuel tank cleaner, following the instructions on the bottle. In some cases, you will need to dilute the cleaner with 1 or 2 gallons of water. Different cars also take different amounts, so refer to the Fuel Tank Cleaner bottle's instructions for guidance. e.Let the cleaner sit for several hours to allow the solution to work on and loosen grime, rust and other deposits attached to the walls of the gas tank. f.Clean the tank out with water from a garden hose. Clean the outside of the tank as well. g.Repeat the first few steps until nothing comes out of the tank. Rinse the tank a few extra times to be sure that it’s completely clean. h.Allow the tank to dry for 24 to 48 hours; be sure your tank is completely dry before reinstalling it. The tank must be completely empty and dry before it is put back on the car. Link to comment Share on other sites More sharing options...
