Is my Mitsubishi Outlander having Electrical/Motor problem?
this could have possibly happen of you have recently had the cooling fans replaced and installed a aftermarket set including the fan module
If so check if the fans is activating the wipers and spray at the same time. Turn on your a/c and this will kick the fans on right away.
