Gear not Smooth
ameens
May be the oil supply is not proper in the gear box, That is why you experience roughness while changing gears. Start with changing the gear oil and gear oil filter to eliminate the dirty gear oil probability. If still same then you may consult the expert and get it checked if the oil is smoothly processing in the gear box.
  • 5 months later...
