antone Posted April 22, 2011 Share Posted April 22, 2011 the handbrake lights and oil light is flickering when stopping in traffic i had got a major service done where the timing belt was changed and so was the head gasket help me pleaseeee Link to comment Share on other sites More sharing options...
samf Posted May 9, 2011 Share Posted May 9, 2011 Check all the fuses, it may be half burnt or blown already and son slight contact it get lit up. If still same then change the oil pressure sensor as its cheap and easy to fix next to oil filter. Its quiet common culprit. For hand brake light, i dont know and i hope someone else will help here for that. Link to comment Share on other sites More sharing options...
antone Posted June 7, 2011 Author Share Posted June 7, 2011 thanks anyways Link to comment Share on other sites More sharing options...
