faisall Posted January 3, 2014 Share Posted January 3, 2014 My BMW 530i making a repetitive click click noise on very slow speed like under 10-15 km. Noise comes from back side and noise is like when some stone is stuck in tire tread and it make click click noise on every tire rotation, but in this case its appearing faster than one tire rotation like 2-3 times per tire rotation and I have checked and cleaned the tire tread thoroughly twice. Any educated guesses guys. Thanks a lot. Link to comment Share on other sites More sharing options...
drdubai Posted January 4, 2014 Share Posted January 4, 2014 Hi. Had a similar problem with my 6. Check out my post. .. clicking sound. Turned out to be loose nuts near the wheel. Drop the exhaust. On the rear of the car u will see a roundiah structure on each side. It has lots of small bolts. Looks like a truck wheel. These bolts were loose. Best of luck. Link to comment Share on other sites More sharing options...
badman Posted January 4, 2014 Share Posted January 4, 2014 Drdubai point sounds quite right, just like to add while at it get the drive shaft also checked as you mentioned that in one tire rotation click comes 2-3 times makes me more think on drive shaft rubbing with some wire or sensor somewhere down the under body. Link to comment Share on other sites More sharing options...
