cesarhost Posted April 13, 2011 Share Posted April 13, 2011 the car is leaking radiator fluid somewhere under the plastic reservoir, the dripping just below the container but can't see where the leak is coming from. pls. help Link to comment Share on other sites More sharing options...
zafart Posted April 15, 2011 Share Posted April 15, 2011 It must be leaking bottle, its quite common. Disconnect bottle completely and pull it out and take it home and check it with water filled with pressure and im sure you will find the leak. Link to comment Share on other sites More sharing options...
