georgesam Posted November 6, 2010 Share Posted November 6, 2010 passenger side window is stuck at little down from top. power window button making no use only lil noise coming while doing up or down but window pane isnt moving. Is this loose circuit or motor? Link to comment Share on other sites More sharing options...
gildi Posted November 6, 2010 Share Posted November 6, 2010 Go to satwa window tinting guys and ask them to open window bottom cover and check for any blockage. If you hear motor working and also putting slight load on battery that means its fine, window pane must be blocked from inside. Link to comment Share on other sites More sharing options...
georgesam Posted November 8, 2010 Author Share Posted November 8, 2010 Problem solved in 100 aed and 1 hr visit to sawta guys. Gildi you were damn right, it was motor. what a mess opening that door from inside. Link to comment Share on other sites More sharing options...
