ronaldeve Posted July 26, 2013 Share Posted July 26, 2013 When doing compression test the preliminary things to bear in mind- 1. Check the fuel pump & fuel-injection fuses, 2. Remove the spark plug and disconnect the main wire to the coil, 3. Place your hand on the spark plug hole threaded end. 4. Turn the ignition and crank the engine couple of times in a stable reading; if you are not sure about this, do take your engine to a authorized service station and get it done. Link to comment Share on other sites More sharing options...
devilrider Posted July 28, 2013 Share Posted July 28, 2013 If the compression of one cylinder is lower than others, then surely there is problem. If two cylinder compression is lower than others, you can add little oil and do the compression test again. If two cylinder opposite to each other is showing lower reading, then head gasket might be tossed. Link to comment Share on other sites More sharing options...
smithson Posted August 1, 2013 Share Posted August 1, 2013 You can get your own compression testing kit from any auto part stores, the kit includes Testing tube Indicator Dial Gauge Adapter for Spark Plug Hole Try this and now you can easily do the compression test. Link to comment Share on other sites More sharing options...
