lokesh Posted January 4, 2011 Report Share Posted January 4, 2011 my 2001 escalade is having a temp gauge issue which is the coolant temp gauge shows coolant is red hot and is stuck even if engine off Link to comment Share on other sites More sharing options...
methecadi Posted January 6, 2011 Report Share Posted January 6, 2011 May be or more than likely your gauge/sensor is gone bad. Check the heating temp by hand of hose from radiator to engine when its at normal running temp (also press that hose little bit to see how hard and soft it is), then when it shows overheat check same hose again by hand and press also little bit to see if that becomes more hard and hotter than before then its actually overheating. If not then temp gauge or water temp sending sensor is gone bad. Change the sensor first its cheap, and then gauge. Hope it helps Link to comment Share on other sites More sharing options...
