abu Posted January 21, 2011 Report Share Posted January 21, 2011 when driving the car at a low speeds it barely moves. it is a 2007 SRK the problem is that the check engine light isn't on. The car only has 67000 km and has had two timing chains changed since i bought it in the past two years. what could be wrong Link to comment Share on other sites More sharing options...
scheal Posted January 22, 2011 Report Share Posted January 22, 2011 why would u have two timing belt change in two years at low mileage???? Get computer check fully if any engine or gearbox issue. Or else look into these following ares: Check brake pads and calliper isnt too tight Check hand brake isnt very tight Check tire pressure is fully inflated Check none of the tire is swollen Check all spark plugs, HT leads and Ignition coil is firing enuf Link to comment Share on other sites More sharing options...
abu Posted January 30, 2011 Author Report Share Posted January 30, 2011 Scheal, it was the ignition coil. thanx man Link to comment Share on other sites More sharing options...
