kelum Posted May 28, 2013 Share Posted May 28, 2013 Since last month my manual corolla having sticky 2nd gear to put in. Rest all gears are fine except the second gear, sometimes when i force to put in it makes grrr grrr noise and then i depress the clutch and try again it goes but with same difficult. Im clueless whether this is a gear issue or clutch or engine issue. Please advise, thanks in advance. Link to comment Share on other sites More sharing options...
timsang Posted June 4, 2013 Share Posted June 4, 2013 In my understanding the gear has to be replaced. how old is your car? Link to comment Share on other sites More sharing options...
autopartsexpert Posted June 9, 2013 Share Posted June 9, 2013 Hi If u are willing to have a survey with our expert in Autotransmission for sure let them survey and let u know the exact fault.. some says replace it but actually might be a repairing fault thanks Link to comment Share on other sites More sharing options...
kelum Posted June 10, 2013 Author Share Posted June 10, 2013 had the gear fixed. Link to comment Share on other sites More sharing options...
shajil18 Posted August 10, 2013 Share Posted August 10, 2013 From where ? Link to comment Share on other sites More sharing options...
autopartsexpert Posted August 17, 2013 Share Posted August 17, 2013 Hi Kelum, Hope your gear problem will be solved cause I believe i have a friend he is specialist in Auto Gear both in Manual and autotransmission. He could better solve out ur problem about gear.. coz i had repaired my auto gear from him and he is not charging a lot.. you may call him if u want .... his number is 055 -4933386......give my reference name Moxx thanks Link to comment Share on other sites More sharing options...
