ronaldeve Posted July 17, 2014 Share Posted July 17, 2014 How does the brake fluid go low in the car? Why does this happen? Link to comment Share on other sites More sharing options...
ihabb Posted May 25, 2015 Share Posted May 25, 2015 If you are trying to reduce the chance of leaking you should know that this is impossible. The fluid usually leaks when some parts are loosen. The best tip is to check this fluid whenever you visit the mechanic. Link to comment Share on other sites More sharing options...
