Too much smoke
  • 3 weeks later...
I think the egine os overheated. Try to touch the engine dash, If you feel is too much heated then may be the engine is overheating. Its bad dude. Open the engine for a while and wait till it cools down. I think there is some leak in the engine. Check for the leaks using the smoke machine.
 Well I think is because of overheating. If your engine is too hot and there is smoke coming out, then yes it’s overheated. Cost of repairing it actually depends on from where the leak is. You might have to get some auto parts replaced.
  • 3 weeks later...
  • 8 months later...
