sadiq Posted August 5, 2014 Report Share Posted August 5, 2014 The wiper motor at the rear screen is not working. Does anyone know how to fix it? Link to comment Share on other sites More sharing options...
farookb Posted August 7, 2014 Report Share Posted August 7, 2014 I suppose there is a fuse problem in the motor. To check the fuse, follow the test light system and check if the fuse is working or not. Link to comment Share on other sites More sharing options...
sadiq Posted August 7, 2014 Author Report Share Posted August 7, 2014 What is test light procedure? Link to comment Share on other sites More sharing options...
farookb Posted August 7, 2014 Report Share Posted August 7, 2014 Test light procedure is use to check the fuse. There is a kit test light kit that you can buy from an auto shop. You need to connect the pointed side of the test light to the fuse connected at the wiper motor. If the test blows, it means the fuse is ok, if not, the fuse is blown out. Link to comment Share on other sites More sharing options...
