culvert Posted May 3, 2012 Share Posted May 3, 2012 Does any body know if there are any better ways to prevent a flat tire. I know that rotating tires and keeping a reserve tire is recommended but does anyone know if there are any other preventive measure we can do? Link to comment Share on other sites More sharing options...
cadyart Posted May 3, 2012 Share Posted May 3, 2012 Aside from making sure that your tires have the correct pressure, you can also do a habit of checking the tire threads. If the tire threads are already half way through, that you might want to replace it only if you really want to avoid getting to situations where you'll get a flat. Link to comment Share on other sites More sharing options...
pancham Posted May 9, 2012 Share Posted May 9, 2012 there is tire rotation that you should be doing regularly. and get the tire balancing as well. Now that the summers are approaching its very important to take care of them Link to comment Share on other sites More sharing options...
gildi Posted June 30, 2012 Share Posted June 30, 2012 dont over use the tires maximum i would say maybe 2 to 4 years and make sure you use good quality tires. rest you can use the above suggestions. Link to comment Share on other sites More sharing options...
abu Posted August 28, 2012 Share Posted August 28, 2012 whenever you park the car dont let the tire touch the pavement as this will reduce the Tire pressure, wobble the car as the tire will disfigure or eve burst. Link to comment Share on other sites More sharing options...
abu Posted September 15, 2012 Share Posted September 15, 2012 Very good information. Link to comment Share on other sites More sharing options...
gildi Posted September 19, 2012 Share Posted September 19, 2012 whenever you park the car dont let the tire touch the pavement as this will reduce the Tire pressure, wobble the car as the tire will disfigure or eve burst. Thats a new finding for me.... Thanks. Link to comment Share on other sites More sharing options...
ketan Posted September 28, 2012 Share Posted September 28, 2012 no matter what you do if the tire has to go flat it will. Link to comment Share on other sites More sharing options...
