CadillacDxb Posted May 8, 2012 Share Posted May 8, 2012 Cadillac Manufacturer Codes Cadillac Network Trouble Code List U1000 - Class 2 Communication Malfunction U1001~U1254 - Loss of XXX Communications U1002~U1015 - Loss of serial communications for class 2 devices U1016 - Loss of Class 2 Communication with VCM U1016 - Loss of Communications with PCM U1017~U1025 - Loss of serial communications for class 2 devices U1026 - Loss of ATC Class 2 Communication U1027~U1039 - Loss of Serial Communications for Class 2 Devices U1040 - Loss of Class 2 Communications with ABS U1041 - Loss of EBCM Communication U1042 - Lost Communications with Brake/Traction Control System U1043~U1055 - Loss of Serial Communications for Class 2 Devices U1056 - Loss of Communications with RSS U1057~U1060 - Loss of Serial Communications for Class 2 Devices U1161 - Loss of PDM Serial Data U1062 - Loss of Serial Communications for Class 2 Devices U1163 - Loss of RRDM Serial Data U1064 - Loss of Communications with DIM U1065 - Loss of Communications with IPM U1066 - Loss of Communications with RIM U1067~U1069 - Loss of Serial Communications for Class 2 Devices U1170 - Loss of Driver Door Switch Asm Serial Data U1071~U1087 - Loss of Serial Communications for Class 2 Devices U1088 - Loss of Communications with SDM U1089~U1095 - Loss of Serial Communications for Class 2 Devices U1096 - Loss of Communications with IPC U1097~U1127 - Loss of serial communications for class 2 devices U1128 - Loss of Communications with IRC U1129 - Loss of Communications with AMP U1130~U1143 - Loss of serial communications for class 2 devices U1144 - Loss of Communications with PHN U1145 - Loss Of NAV Communications U1146 - Loss Of Onstar Communiction U1147~U1151 - Loss of serial communications for class 2 devices U1152 - Loss Of ACM Serial Data Communication U1152 - Loss of Data HCM U1153 - Loss of Communications with CCP U1154~U1159 - Loss of serial communications for class 2 devices U1160 - Loss of Communications with DDM U1161 - Loss of PASS Door Module SBI U1162 - Loss of Rear Driver Door Module SBI U1163 - Loss of Rear PASS Door Module SBI U1164 - Loss Of DIM Serial Data Communication U1165 - Loss of serial communications for class 2 devices U1166 - Loss of Communications with SCM U1167 - Loss of serial communications for class 2 devices U1168 - Loss Of TTM Communications U1169 - Loss of Communications with MMM U1170 - Loss of Driver Door Switch SBI U1171~U1175 - Loss of serial communications for class 2 devices U1176 - Loss Of RFA Communications U1177~U1191 - Loss of serial communications for class 2 devices U1192 - Loss of VTD Class 2 Serial Data Com U1193 - Loss of VIM Class 2 Communication U1194~U1254 - Loss of serial communications for class 2 devices U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) U1300 - Class 2 Short to Ground U1301 - Class 2 Short to Battery U1304 - Loss Of UART Communications U1305 - Class 2 Data Link Low or High U1500 - Inter-Device Dedicated Bus Malfunction U1713 - Loss of Front Door Module to Window Motor High Speed Comm. U1715 - Loss of Front Door Module to Window Motor High Speed Comm. U1714 - Loss of Front Door Module to Window Motor Normal Speed Comm. U1716 - Loss of Front Door Module to Window Motor Normal Speed Comm. U1800 - Controller Area Network (CAN) Bus Communication U2000 - Invalid BFC Transmitted SPI Data U2001 - Invalid IPC Transmitted SPI Data U2002 - SPI Data-In Low U2003 - SPI Data-In High U2004 - SPI Data-Out Low U2005 - SPI Data-Out High U2006 - SPI Clock-Out Low U2007 - SPI Clock-Out High U2050 - SIR PPS/CPS Communications Link malfunction U2100 - Controller Area Network (CAN) Bus OFF U2100 - CAN-BUS Communication Malfunction U2102 - More Controllers on Bus than Programmed U2103 - Fewer Controllers On Bus Than Programmed U2104 - CAN Bus Reset Counter Overrun U2105 - CAN Bus Error ECM U2105 - Lost Comm with Engine Control System U2106 - Lost Comm with Trans Control System U2107 - Lost Communications with Body Control System U2108 - CAN Bus Error ABS U2108 - Lost Comm with ABS Control System U2150 - Navigation ECU Gateway Communication Error U2151 - Navigation ECU Communication Malfunction U2153 - VICS ECU Communication Error Link to comment Share on other sites More sharing options...
