Auto Lock
This is usually a feature of central lock and it depends if the 2015 LC comes with this feature or not. Secondly it also depends if this feature was enable or not by adding additional wiring as it require little bit extra work to wire the speed function with central lock.
I am sure you are looking for something, that if car goes above 10 km/h speed all door should be automatically get locked. First check with dealer if such function can be enable, as they might not have enabled such such feature as many don't like it. If they say they cannot as such feature does not exist in installed central lock module, then you only need to change the central lock module for less than 100 - 200 dirham from deira or sharjah shops and inform the guy who install the module that you want this feature enable before he start the job, so that he can lay the wiring accordingly and also choose the right central locking module.
