shakeelkhan Posted April 23, 2011 Share Posted April 23, 2011 the airbag light has come off but there is no difference in the car. how can i switch it off Link to comment Share on other sites More sharing options...
Shabir Posted April 28, 2011 Share Posted April 28, 2011 Get the computer code of fault and clear it and see if it comes back again after you start or after few kms driving, then that means there is something wrong and chang that part as the fault code. In some case it shows up just like that, and once you clear the code it doesnt come back again. Link to comment Share on other sites More sharing options...
erfankr Posted May 25, 2015 Share Posted May 25, 2015 How do you turn off your air bag? Do you use a key for that? Maybe you or someone who used your car accidentally turned it off? You also need to check the electronics in your car. Link to comment Share on other sites More sharing options...
