tuffy Posted June 7, 2011 Share Posted June 7, 2011 i have discover a leak in the rear main engine seal i am not sure what is leaking and how can i fix it any clues here Link to comment Share on other sites More sharing options...
abaid Posted June 11, 2011 Share Posted June 11, 2011 Leak from engine is engine oil. If its very minor, its pretty acceptable and if its major that after every parking you see spot on floor get it fixed. For fixing you ned that rear seal and mechanic who can lift the car and fix the seal from behind the engine. Its pretty straight forward but technical job. Link to comment Share on other sites More sharing options...
tuffy Posted June 16, 2011 Author Share Posted June 16, 2011 then i will take it to the technician thanks Link to comment Share on other sites More sharing options...
