Minimum distance between front tyres to front bumper
Hi,
if anyone can tell what is the Minimum/standard distance between front tyres to the front bumper, as my tyres are touching front bumper if I am going above 80 KMPH and also while turning.
This is not the issue of oversize tyre.
This is a common problem with the Pajero after a desert drive. You had hit the front bumper and it has moved in a little. Since it's made of fiberglass you cab just pull it out. No point spending money in a workshop.
If you plan do offroading i suggest to remove the lower plastic black lip (where you have circled). There are only two bolts and would help a lot
  • Like (+1) 8
