bruce Posted July 27, 2011 Report Share Posted July 27, 2011 I would appreciate if i can get instructions on how to change the thermostat? Link to comment Share on other sites More sharing options...
rajpaul Posted July 28, 2011 Report Share Posted July 28, 2011 Follow the below procedure:- 1. Remove the lower and top hose 2. Undo the heater hoses 3. Remove the thermostat and then flush out the radiator completely 4. Block and heater core 5. Install new thermostat replace any defected hoses if any 6. Add the coolant and bleed air from system 7. in the last run the engine with heater open feel for heat in both heater hoses as to ensure no air trapped in heater. hope this helped Link to comment Share on other sites More sharing options...
