Morning Newbie Desert Drive - Area 53/Around - Sharjah - 5 Nov 2021
dune jockey
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines.
MUST READ AND TOTALLY AGREE:
Drive Details
Level:  Newbie and Above
When:  5 Nov 2021, Friday.
Meeting time: 6:30 AM (SHARP - Without any exceptions)
Meeting Point: https://goo.gl/maps/LdEjQdBufXo2Dq4q8
Approximate finish time: 10:00 AM, 5 Nov, Friday
THIS IS A COMPRESSOR ONLY DRIVE. WE WILL  ENDING THE DRIVE A POINT, WHICH IS NOT CLOSE TO AN AIR LINE. IF YOU DO NOT HAVE A COMPRESSOR, PLEASE DO NOT SIGN UP FOR THIS DRIVE. IF YOU ARRIVE AND HAVE NO COMPRESSOR YOU WILL NOT BE ALLOWED TO JOIN THE DRIVE.
LIMITED SPOTS AVAILABLE:
  • Limited to 12 cars only. RSVP will close on Thursday - 3:00pm
Please RSVP on the Calendar below
1 hour ago, Adam James said:
Good morning
Please can you waitlist myself and @Alex Hollands as first drives?
Thanks
There is one spot vacant as of now, which of you want to be added. Hopefully by Friday there might be some sign outs and both can join
@Chaitanya D I have left this drive as joining a Fewbie drive at that time, which had spot and I see there is waitlist for this drive so please see that someone else benefits from this spot. Thanks!
Considering this
@Adam James
@Alex Hollands
both will be added to the drive
please confirm
6 minutes ago, munkybizness said:
Hi @Chaitanya D, any chance you can squeeze in an extra car? I can help with any shoveling + support 🙏🏽
Sure, welcome.
Hello, the map is not opening for the meeting point.
Is it only for me or others are having the same issue?
many alternatives?
