goara Posted April 25, 2011 Report Share Posted April 25, 2011 the front axel boot needs a change due to a bent and crank. my question is do i need to change the front as well even if its not damaged thanx Link to comment Share on other sites More sharing options...
chaman Posted May 8, 2011 Report Share Posted May 8, 2011 Axel boot is half consumable item which age as per time and km. Once its cracked and torn it losses the grease and its time to change. Change only the ones which is torn and cracked that has leaked all the grease. No need to change the one that is fine and fully loaded with grease inside. Link to comment Share on other sites More sharing options...
