Jerry Han Posted September 16, 2022 Share Posted September 16, 2022 Hi, i noticed recently my AC lose power (less cold) when i exceed 140km/hr and 3000rpm. And sometimes my bluetooth also get disconnected along with AC problem. I could reset the problem by turning off and on the engine again. Has anyone experienced this before and what is the possible cause and solution? 1 Link to comment Share on other sites More sharing options...
Frederic Posted September 16, 2022 Share Posted September 16, 2022 Hi @Jerry Han Are you sure this only happens when you exceed 140km/h and 3000rpm ? I do not see a specific relationship to speed to see this occuring. Bluetooth getting disconnected along with AC problem sounds a bit like either a battery that is on its way out, or a faulty electrical connection somewhere near the battery or junction box. I would start to check this first. 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
GauravSoni Posted September 16, 2022 Share Posted September 16, 2022 Hey @Jerry Han You can check the following thread.. Does the AC come back on as you slow down? try driving at 100 kmph on the highway ( on long drives) and see if you still have the issue.. I have recently experienced that when i drive at speed limits, the AC air is not as cold as it is when i drive at 100- 110.. 1 Link to comment Share on other sites More sharing options...
