Popular Post Luke K P Posted December 10, 2023 Popular Post Share Posted December 10, 2023 Taking inspiration from @Stumpy Paj I decided to go ahead with installing onboard air via arb single compressor. I decided to mount inside the space where the spare wheel goes, and run the air outlet to the side where I have a hard mount for the insta360 camera. Very simple job once you have drilled the mounting holes in the wheel mount. Terminated to ground on the factory point inside the rear space, and extended hot power to battery with inline switch at battery. Extended the pressure sensor and isolation switch up into the auxbeam gangpanel controller recommended by @Frederic. Super happy with the result. Here are some pics. 5 2 3 Link to comment Share on other sites More sharing options...
