aboo Ibraheem Posted February 16, 2013 Share Posted February 16, 2013 CHECK IT OUT ON THIS LINK Link to comment Share on other sites More sharing options...
ankit Posted February 23, 2013 Author Share Posted February 23, 2013 thanks. Link to comment Share on other sites More sharing options...
rishy Posted February 26, 2013 Share Posted February 26, 2013 yeah thank. Link to comment Share on other sites More sharing options...
ankit Posted April 14, 2013 Author Share Posted April 14, 2013 aboo do you have a good workshop reference to get the car serviced? Link to comment Share on other sites More sharing options...
aboo Ibraheem Posted April 14, 2013 Share Posted April 14, 2013 HERE IS ONE GARAGE IN RAS AL KHOR, THEY REPAIRED MY CAR THROUGH INSURANCE, THINK THEY ARE QUITE GOOD, PRICES SEEMED TO ME QUITE REASONABLE, BUT TRY YOURSELF AND LET US KNOW WHAT YOU THINK: AL ZAROUNI AUTOMOBILES 04 3333 689 0505491305 OR 0502468050 Link to comment Share on other sites More sharing options...
ankit Posted May 27, 2013 Author Share Posted May 27, 2013 thanks for the address aboo Link to comment Share on other sites More sharing options...
aboo Ibraheem Posted May 27, 2013 Share Posted May 27, 2013 ANY TIME YOU'RE WELCOME! DID YOU GET YOUR CAR SERVICED? Link to comment Share on other sites More sharing options...
ankit Posted May 30, 2013 Author Share Posted May 30, 2013 i did get the car service form some place else. Link to comment Share on other sites More sharing options...
fordafford Posted June 1, 2013 Share Posted June 1, 2013 why is my mechanic saying that spark plugs are the most critical part of the car? Link to comment Share on other sites More sharing options...
aboo Ibraheem Posted June 2, 2013 Share Posted June 2, 2013 fordafford wrote: > why is my mechanic saying that spark plugs are the most critical part of > the car? Spark plugs are little devices inside the cylinder that take in high voltage electricity at one end and create a spark at the other end. There, the spark ignites the gas and air mixture, and the resulting combustion is what ultimately powers the car. This service involves removing the old spark plugs and replacing them with new ones. Should I do this service when it's recommended? Yes. Why do I have to do this? At the sparking end of the spark plug is a built-in gap between two or more little pieces of metal, called electrodes. When the plug fires, one or more sparks jump that gap and a tiny bit of the metal is burned off. This happens hundreds of times every minute. Over time, the gap between the metal tips gets too big. Also, your spark plugs can get fouled, but that would indicate that you have a problem. What happens if I don't do this? Your engine will start to misfire and run poorly, performance will suffer, efficiency will decrease and emissions will dramatically increase. Your car may also be difficult to start. Link to comment Share on other sites More sharing options...
