Audi Scheduled Maintenance Procedures
* Rotate and Inspect tires
* Inspect Automatic shiftlock operation
* Inspect Axle seals, ball joints & tie rod ends
* Inspect Battery electrolyte level
* Inspect Brake system
* Inspect Cooling system
* Inspect Drive shaft boots
* Inspect Drivebelts
* Inspect Engine (leaks)
* Inspect Exhaust system
* Inspect Fluid levels
* Inspect Lights
* Inspect ODB System check for codes
* Inspect Power steering fluid
* Inspect Spare tire
* Inspect Timing belt drive with manual tensioner
* Inspect Timing belt tension system
* Inspect Transmission (leaks)
* Inspect Transmission final drive fluid
* Inspect Underbody
* Inspect Wheels, tires, spare
* Inspect Windsheild washer system
* Inspect Wiper, washer, headlight washer
* Inspect/Adjust Exterior lights
* Inspect/Adjust Head lights
* Inspect/Check date Tire repair set
* Inspect/Clean Plenum water valve
* Inspect/Lubricate Door hinge mechanism
* Inspect/Lubricate Roof mechanism
* Inspect/Lubricate Sliding roof rails
* Inspect/Lubricate Sunroof rails
* Inspect/Lubricate Wiper arm pivot points
* Inspect/Reset Service reminder light
* Replace Air cleaner element
* Replace Automatic transmission fluid
* Replace Brake fluid
* Replace Cabin air filter
* Replace Drive belt(s)
* Replace Engine oil & filter
* Replace Multitronic transmission fluid
* Replace Spark plugs
* Replace Timing belt
  • Carnity unpinned this topic
