AudiDxb Posted November 9, 2010 Share Posted November 9, 2010 Audi Scheduled Maintenance Procedures * Rotate and Inspect tires * Inspect Automatic shiftlock operation * Inspect Axle seals, ball joints & tie rod ends * Inspect Battery electrolyte level * Inspect Brake system * Inspect Cooling system * Inspect Drive shaft boots * Inspect Drivebelts * Inspect Engine (leaks) * Inspect Exhaust system * Inspect Fluid levels * Inspect Lights * Inspect ODB System check for codes * Inspect Power steering fluid * Inspect Spare tire * Inspect Timing belt drive with manual tensioner * Inspect Timing belt tension system * Inspect Transmission (leaks) * Inspect Transmission final drive fluid * Inspect Underbody * Inspect Wheels, tires, spare * Inspect Windsheild washer system * Inspect Wiper, washer, headlight washer * Inspect/Adjust Exterior lights * Inspect/Adjust Head lights * Inspect/Check date Tire repair set * Inspect/Clean Plenum water valve * Inspect/Lubricate Door hinge mechanism * Inspect/Lubricate Roof mechanism * Inspect/Lubricate Sliding roof rails * Inspect/Lubricate Sunroof rails * Inspect/Lubricate Wiper arm pivot points * Inspect/Reset Service reminder light * Replace Air cleaner element * Replace Automatic transmission fluid * Replace Brake fluid * Replace Cabin air filter * Replace Drive belt(s) * Replace Engine oil & filter * Replace Multitronic transmission fluid * Replace Spark plugs * Replace Timing belt Link to comment Share on other sites More sharing options...
