marcusa Posted June 1, 2011 Share Posted June 1, 2011 what is an aporx time required to change the head gasket as mine is leaking big time and dont think i should cont. driving till its fixed. thanks Link to comment Share on other sites More sharing options...
ismilekhan Posted June 1, 2011 Share Posted June 1, 2011 It will take atleast 2 days to fix and if its leaking from long time then dont waste money in head gasket better swap the engine as im more than sure when u open the head and send for lathe they will tell you that head is bend and cant be faced and hence you got to replace the engine head. Cost of head and whole engine must be close to each other depending on ur model of CR-V. Good luck mate. Link to comment Share on other sites More sharing options...
marcusa Posted June 19, 2011 Author Share Posted June 19, 2011 thanks mate Link to comment Share on other sites More sharing options...
