Morning Fewbie Plus Drive - Fayah Technicals - Abu Dhabi - 30 AUG 2026
_luke_
DRIVE DESCRIPTION
A three-course serving of Al Fayah, with something different waiting in each section of the drive.
The Entrée: We’ll start from the usual Fayah location and warm things up with some long-range dune riding, getting into the flow before the terrain tightens up.
The Main Course: Then it’s into the infamous Fayah Technical Zone. This is where we’ll slow things down and focus on driving smoothly and continuously through soft, difficult terrain. The aim is not to attack every obstacle, but to read the sand, maintain momentum and keep the convoy flowing through the maze.
The sand will be soft.
There will be refusals.
The temps will be H O T.
Keep your wits about you and expect to work for your lines. And if we somehow make it all look too easy, there’s a simple solution: back onto the sabkha, return to the start, and do it again. 😎 There is no reward for finishing fast!
The Dessert: If time and temperatures allow, we’ll finish with a visit to the desert safari play area for some faster driving and a few big, tall sidies.
A bit of flow, a lot of technical sand, and hopefully just enough punishment to earn dessert.
DRIVE DETAILS
Level:  Fewbie Plus and above
Meeting time: 06:30 (SHARP - Without any exceptions)
Meeting Point: https://maps.app.goo.gl/3xbwgCT6BvjU6ZCx7
Meeting Coords: 24.380892, 54.987935
Approximate finish time: 10:00
LIMITED SPOTS AVAILABLE
  • This drive is limited to 8 cars only. RSVP will close on Saturday 12:00
  • If the RSVP is full, you can add your name to the waitlist, once someone drops, you will be moved to the RSVP list.
  • Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others.
  • Repeated no-show members after RSVP will have their account suspended for a month
  • Well Done (+2) 2
