Sam Selim Posted August 24 Share Posted August 24 DRIVE DESCRIPTION A refreshing morning run from Lisaili to Qudra, making the most of the cooler early hours and open desert. Expect a smooth, flowing drive across rolling dunes, some technical areas, with plenty of opportunities to enjoy sweeping lines, gentle climbs and some playful ridge work along the way. Fresh air, open dunes and good morning vibes - the perfect way to start the day. 🕖 DRIVE DETAILS Level: Fewbie and above (All Levels) When: 29 August 2026, Saturday Meeting time: 06:30 AM - Sharp (Without any exceptions). Meeting Point: https://maps.app.goo.gl/pyZGRcAbZptdWhfv5 (24°54'33.4"N 55°31'42.8"E) Approximate finish time: 10:00 AM 🚗VEHICLE REQUIREMENTS Any proper 4x4 vehicle. If in doubt, please mention on the drive topic. Front and rear tow hooks / recovery points. 8–10 inches minimum ground clearance 🎒 WHAT TO BRING Loads of water, snacks, smiles, enthusiasm and willingness to learn. We also recommend adequate protection from the sun and closed shoes. 🧰 OFFROAD GEARS Tire deflator and Tire pressure gauge. Air compressor. A programmable Walkie-talkie radio. Off-road safety flag. A proper shovel. First-aid kit and Fire extinguisher. ✅ RSVP Confirm your attendance by clicking on "GOING" in the Calendar Event. Your name will appear on the RSVP list. If the RSVP is full, add yourself to the waitlist. As soon as a spot becomes available you will be moved automatically to the RSVP list. The RSVP closes one day prior to the drive Latecomers will be turned back (no exceptions) No RSVP = No Drive Please withdraw your RSVP if plans change Repeated no-shows may result in 1-month suspension Link to comment Share on other sites More sharing options...
