yazeed Posted January 10, 2012 Share Posted January 10, 2012 Hi guys, I believe the exhausts are leaking water under the car in the front, what is the name of that box attached to the exhaust line that has carbonfiber texture on it? It's leaking directly below it, is it safe to drive in this case, and how could this happen in a new car? Link to comment Share on other sites More sharing options...
ismilekhan Posted January 10, 2012 Share Posted January 10, 2012 Exhaust cant leak water from front, as then you will hear loud hissing noise if exhaust is leaking. Exhaust generally throw few droplets of water occasionally from tail pipe in end, that considered to be good sign of nice engine. What you must be seeing is the AC condenser water droplet, drive the car without AC and see if still it leaks water. If it does, better take it to dealer and they should sort out as its 2012 model such an expensive car. AC condensation is quite normal and you don't need to worry about, thats a normal behavior of every car. Link to comment Share on other sites More sharing options...
